Do you mean a 4efe?
The main causes of high idle Is a leak into the inlet manifold. Could be a Pipe off or even the diaphragm split in the brake servo. I suggest you check your throttle is fully closed first. Then move onto plugging each pipe individually that goes to the inlet manifold. But it could be anything on the inlet.
Or it could be the idle control valve they are located under the throttle body on the N/A's and on the side of the inlet manifold for glanzas
Edited by micky boy
Do you mean a 4efe?
Yea! Sorry!! Right .. Is it worth taking the throttle body off and giving it a good clean out?
