russ78 Posted May 23, 2012 Posted May 23, 2012 got a problem with my aftermarket lambda sensor, so i thought ok ill remove the one from my cat but it seems to be in there very well and i cant remove it.i cant get a ring spanner over it as theres not enough room any ideas other than wd40 ?is there some trick to getting em out ? Quote
Max9650 Posted May 23, 2012 Posted May 23, 2012 when i replaced my decat the lamba sensor was stuck in there, took it to a random parts supplier who kindly heated it up and got it out for me - sorry i cant be better help Quote
AdamB Posted May 23, 2012 Posted May 23, 2012 I got a pair of adjustables on mine and it came out straight away mate. Spray some WD over it and try and give it a crack. Quote
Flaminsam Posted May 23, 2012 Posted May 23, 2012 They are a pig to do. Better off removing it and putting it In a vice? Quote
russ78 Posted May 23, 2012 Author Posted May 23, 2012 yeah its being a complete pig tbh, its already removed only thing i can think is to cut the cat to get it out but i need the cat for mots and that Quote
daniel_g Posted May 23, 2012 Posted May 23, 2012 Any mechanic mates with the special o2 remover tool, thats what i'd use. Or get a socket over it and use a big breaker bar. Quote
russ78 Posted May 24, 2012 Author Posted May 24, 2012 you cant get a socket over it as the plug is to large looks like ill have to try a mechanic Quote
m11xky Posted May 24, 2012 Posted May 24, 2012 yea mine was super tight! spray the wd over a fre times, leave it over night and try the next day. if its unplugged from the car you shoud be able to get a ring spanner on it....but you need it in a vice.. its still very tight tho! Quote
Azz Posted May 24, 2012 Posted May 24, 2012 I cut the wires and used a socket then re-soldered the wires, still works perfect Quote
russ78 Posted May 29, 2012 Author Posted May 29, 2012 yeah i know got local mechanic to remove it was freebie to Quote
