jellybaby Posted June 5, 2012 Posted June 5, 2012 Hello every one me again I brought a forged engine had all valve stem seals done replaced erc and loads of other bits but on idle the slight blue smoke. When boost and driving fine nothing just on idie maybe slight bit of over fuel or might be a sticky lifter Quote
A L 3 X Posted June 5, 2012 Posted June 5, 2012 Turbo? Mines doing the same and have been told it may be early signs of the turbo seals? Quote
AdamB Posted June 5, 2012 Posted June 5, 2012 You done a compression test buddy just to rule out anything internal? Assuming it was a second hand forged engine?I have seen turbo's that are brand new still be faulty mate so don't rule it out. Quote
jellybaby Posted June 5, 2012 Author Posted June 5, 2012 All bob on compression test wise and yer second hand but member on here and he a good feller he was told it poss need to b shimmed a little ir then again I think it could b a sticky lifter just need opinions and that true the turbo off ATM anyway as redoing my engine bay and bits and bobs so mite go get it checked Quote
Jhandy Posted June 5, 2012 Posted June 5, 2012 I was told by a engine specialist blue smoke on idle is valve stem sills??.? Quote
jellybaby Posted June 5, 2012 Author Posted June 5, 2012 Not checked that I have a look at that 2 moz Quote
