jakeep82 Posted June 6, 2012 Posted June 6, 2012 Just need confirmation a starlet gt turbo wheel stud spline diameter is 13.1mm right ? bought 8 of a lad online and went to put them in and they are too loose !! has he sent me wrong ones or have i ordered wrong size in the write up it says 13.1mm spline diameter Quote
jakeep82 Posted June 6, 2012 Author Posted June 6, 2012 http://www.ukstarletclub.com/forums/index.php?app=ccs&module=pages§ion=pages&id=2&record=19There the brakes im fitting and want longer wheel studs the link it gives you is to m12 x1.5 63mm long with a 13.1 spline :/ im confused haha !! Quote
klyfax Posted June 9, 2012 Posted June 9, 2012 (edited) Toyotas are M12x1.5. Hondas are M12x1.25.Hiace studs are longer. And will fitt perfect. But dont know how long they are... Edited June 9, 2012 by klyfax Quote
akyakapotter Posted June 9, 2012 Posted June 9, 2012 I have 12 m12x 1.25 1inch longer than standard got them for a colt bloody expensive those things lol Quote
WallaceGlanza Posted June 9, 2012 Posted June 9, 2012 (edited) That spline does sound small.... I'm using these with 15mm spacers:http://www.ebay.co.u...=item564240ddadI used an hydraulic press to fit them in the rear discs and a impact gun to pull them through the front hubs. Edited June 9, 2012 by WallaceGlanza Quote
jakeep82 Posted June 11, 2012 Author Posted June 11, 2012 i have some 13.1mm and some 14.3mm studs at home the 13.1 are too small and the 14.3 are to big ? what size do i need to get to slot straight into my standard hubs ? Quote
snails ep91 Posted June 11, 2012 Posted June 11, 2012 ive got 12 63mm long ones spare for these if you want mate id sell you.exactly same as the ones in link just the longer versions and arebrand new. and they fit in starlet hubs as i have used em on mine. Quote
