Amz09 Posted June 6, 2012 Posted June 6, 2012 (edited) For sale is my polo 6n2 16v (100bhp)I have owned the car for around 3years and haven't really had much problems with it in that time apart from the peddle box giving way.its covered just over 116000 miles a lot of this is motorway and mileage is likely to increase as daily drive. The car was standard when purchased and has had a few modification since.Gti splitter De-wiperedTatechnix adjustable coiloversSmoothed front and rear bumpersSmoothed boot lid (rear handle taken off, boot solenoid fitted with button installed)Roof resprayed in satin blackInterior dash plastics resprayedBad bits: the front and rear bumpers have slight scuffs and the bonnet has got key mark with slight laquer peel. The driver side window switch operating the passenger window likes to go up but not down, works fine from passenger control, switch needs replacing or even just a quick clean and there is a problem with the gearbox, this needs replacing along with the peddle box.MOT expires in OctoberTax expires end of JuneI am looking for £1100 as i need it gone.Location: SurreyLots of pics for you allThanks for looking. Edited June 8, 2012 by Amz09 Quote
Starlet__SR Posted June 6, 2012 Posted June 6, 2012 If theres a problem with the gearbox, more than likely it'll be the rivets that hold the diff together. They tend to pull themselves apart, causing the box to self destruct, just a warning:)Day Quote
TrisK Posted June 6, 2012 Posted June 6, 2012 The windows will be a broken wire in the door mateSo you can fix that easy for the saleIf you need more info on where to check message me Quote
Amz09 Posted June 6, 2012 Author Posted June 6, 2012 (edited) If theres a problem with the gearbox, more than likely it'll be the rivets that hold the diff together. They tend to pull themselves apart, causing the box to self destruct, just a warning:)DayLol cheers mate. I don't think that's the prob as I use it daily and the problem seems 2 come and go. I think it might be the drive shafts but garage near work said gearbox but not totally convinced. Edited June 6, 2012 by Amz09 Quote
Amz09 Posted June 6, 2012 Author Posted June 6, 2012 The windows will be a broken wire in the door mateSo you can fix that easy for the saleIf you need more info on where to check message meYeah I thought it prob be a quick fix but hardly get the time 2, and as it's not really bothered me much I just left it.But thanks for the info mate. Quote
Amz09 Posted June 7, 2012 Author Posted June 7, 2012 Price drop £1300 as I need it gone as soon as really. May be getting another car by weekend. Quote
The Toffinator Posted June 7, 2012 Posted June 7, 2012 Think the gearbox problem will stop you selling the car easily dude, i would diagnose it properly if i were you... Quote
Amz09 Posted June 8, 2012 Author Posted June 8, 2012 Yea I think your right. Left it with mechanic so should get a Better idea by end of today. Quote
Amz09 Posted June 10, 2012 Author Posted June 10, 2012 £1000 really need it gone as my v is here. Quote
