Just wondering if anyone knows what does a butoon do on the gearstick (automatic)
It's a toyota bb 2006 model. There is 2 buttons. one on top, push in to engauge gear and one on the side (it's very small)
I have no idea what this does.
Also. Anyone got any idea how to remove a aftermarket (I guess) double din sony head unit? Will I need a sony key to grip the sides? Only want to remove it to check the wires. the rear speakers isn't working
For the stero slide a small peice of thin meatal down the side with the face of normaly to disengae the cage lock unless its bolted in wich case the whole console needs stripping out. as for the button id guess an overdrive for the auto box to give it a more economical top end.
Thanks for the reply.
I just noticed it's overdrive. so another quick question,
Is it eco to have over drive on or off? when I press the button it says O/D off on the dash. is that more eco?? when I press the button again, the light goes out, so I guess thats in normal mode.
Drive with overdrive on for economy. The 2 buttons that say pwr and man can be used aswell, select man for economy and pwr for performance.
