Picked up my new car today. So much fun to drive especially in the wet.
Its a 1990 Mazda MX5 NA6C 5spd manual.
Needs a little bit of work done to it, mainly the roof needs replacing (came with a brand new one, just needs to be installed) and the clutch will need changing at
some point, accidentally went from 2nd to 5th and the revs didnt drop :oops:
Plans will be to lower it and chuck on my OG oldskool wheels and just drive it as its rather fun to drive as it is.
Edited by siren676
  • 1 month later...
Got a paddle clutch made up as i wanted to future-proof it for any mods i can possible afford in the near future
Got some 205/50-15's fitted to my 15x8's
And took it drifting (sorta)
Next step is a set of lowering springs which it majorly needs
Edited by siren676
looks clean dude :) why not get the coilovers off ebay? they are cheap as lowering springs, but they are well worth the money
search mx5 rokkor coilovers on ebay, they have black springs and red locking collars try to avoid the ta technix ones with black locking collars and red springs
also go for the mk2 ones and get some mk2 topmounts as they sit you 20mm lower than the mk1 topmounts
coilovers
http://www.ebay.co.uk/itm/COILOVER-MAZDA-MX5-NB-MK2-ADJUSTABLE-SUSPENSION-/251100372118?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a76bf9c96#ht_3080wt_1270
top mounts can be bought from a guy called 'junk yard dog' on mx5nutz forum
Wanting to keep away from coilovers for a while as they require certification over here. :( Which is basically a plate which lists modifications and says my cars safe with them and if anything is changed it requires re-certification.
Would i just be able to use my current top mounts if i got one of those kits?
Edited by siren676
I will definitely consider those ones for the future, as the price of them + certification is only just more than a set of springs.
So if i read correctly all i need to do is attach my tophats to the mk1 coilovers and im away happy?
Bought some tein lowering springs which were rated at a 40-45mm drop.
Took around 8 hours to install them as it was my first time doing suspension on the car and i only had manual spring compressors
For some reason it didnt lower the car by much. Going off the before and after measurements it only lowered it by 15-20mm so im a little disappointed by it.
Am probably going to get a refund on the springs and put the money towards some coilovers that ryan mentioned above.
Edited by siren676
Took the car to the guy who sold me the springs today and we worked out why they dropped the car so little.
We think that the factory springs had already sagged 20mm or so from factory height causing there to be little difference after installing the teins as they were rated at 40mm from factory height
Will be ordering some coilovers off ebay tomorrow once my pays come through :D
Was about to hit buy now on the coilovers when i checked a local mx5 parts place called mx5mart. The first listing caught my eye and i called the guy up straight away and said i'll buy it.
It was a version 2 hardtop with heated window, insulated roof and it was red! :D Cost a little more than i had so parents have shouted me the difference as an early birthday present.
Picked it up for $1300 (~660 GBP) which is understandable since its winter and everyone wants them.
The extra weight of it has lowered the rear of the car slightly so im happy with the height for now (till i can afford some coilovers)
  • 3 weeks later...
Car looks a bit lower now so ill be happy with it till i can afford some proper coilovers.
Its a R Package front lip, got it for $180 inc shipping from ebay as i couldnt find anything i liked over here.
Edited by siren676
  • 4 months later...
Forgot the forum had changed to a different web address and was updating my build on uksc lol
Got some coilovers way back in October.
They are a Japanese brand called ACRE. They have 10kg front springs and 8kg rear
Got them installed by a mates tyre place where i also got the guards rolled and a wheel alignment
Was a little fun trying to get it to align properly. Finally got it to ~2mm toe in front and rear, 5º caster, -1.5º camber on the front and -2º on the rear.
Its running as little camber as the adjustment would allow at this ride height which im pretty happy with (~90-95mm to chassis rails)
Got a hardtop spoiler from Carbon Miata in real carbon fibre :yahoo:
Also just the other week i got a new torsen lsd out of an 1800cc NA mx5.
It was an absolute prick of a thing to swap but it was well worth the effort
Plans now are to get some smaller tyres, lower it more, get a roll bar then start saving for a supercharger :D
Comments are welcome as always.
(will try fix broken image links in other posts)
