Hi
Need help fitting steering wheel boss the plug thing as in picture comes in the way and i cant get the boss on? And if i remove the plug inwont be able to get the horn to work. Can somebody please help me how they fitted theirs?
Just binned mine. had that on my first v. the horn can still work you just need to make sure its earthed down to meatal inside the boss iirc.
The wheel aint on. i know exactly.what he is on about, its a random unit behind the wheel that the cables from the oem wheel connect too.
Do you just rip it off? The boss has got earth wire to horn plate thing , but the red and black horn wire where will i connect them if i bin the bit in the pic i know the go on horn button but what about other side
Edited by Hawwy
The 96 year glanzas have a different setup to the 97 ones the same as above when i did mine i removed to all and fitted a new button for the horn in the dash
  • 3 weeks later...
If i take the full thing iff pictured then when putting me new steering wheel on ther is a massiv gap around the wheel because the steering cowl is shaped to the bit in picture and boss is smaller
Gap is probably unavoidable unless you make like a rubber spacer which I'm gonna try to, I'm sure if there was an easy way Socks would have done it lol ;)
And the horn just needs wiring direct mate, so the connector you unplugged from the horn needs wiring to the horn button
But what's on the other side of the squib(not taken mine off yet), I assume there will be the other side of the wires?
All the squib does i have metal plates inside which stay in contact even if the wheel is turned without tangling
N haha I'll see what I can do, depends when my
Omp rep
Arrives.
  • 2 weeks later...
Was thinking about this myself yesterday. because want to take off the oem wheel and put on an aftermarket one.
I have this squib, and want to keep it on. As it helps with the cancellling indicators.
Any ideas lads?
