Chand Posted July 8, 2012 Posted July 8, 2012 Hi I've got a set of Rota grid's and just having difficultly finding which centre caps actually fit :/ I've had the rota small DOME caps which does fit inside the centre of the alloys But once on the car the drive shafts stick out and push them out So I then bought a set of the MEDIUM TOP centre caps And they are to big to fit in side the centre of the alloy but it would give it enough clearance if they did for over the drive shafts etc If someone has had the same problem could you please help lol Thanks Quote
Liam_D Posted July 8, 2012 Posted July 8, 2012 Use the normal dome ones but get some 5mm front spacers from Halfords or something and they'll fit a treat Quote
A L 3 X Posted July 8, 2012 Posted July 8, 2012 I had to mod my standard ones to fit without the shafts knocking them out, as spacers were causing the wheels to rub Quote
A L 3 X Posted July 9, 2012 Posted July 9, 2012 Ill sell you my modified ones for £100? ;)nah maybe you can mod the medium tops? Quote
Chand Posted July 10, 2012 Author Posted July 10, 2012 £100 wow that's mates rates lol Yeah il have to have a look into it Thanks for your help But if you do wanna sell yours I'd consider it lol but not for £100 lol Quote
A L 3 X Posted July 10, 2012 Posted July 10, 2012 Haha, it might be a bit difficult with the med tops being too big to fit in the holeIf you bought another pair of flat ones, I could probs mod theMedium tips to fit on your flat bases of that makes sense? Quote
Chand Posted July 11, 2012 Author Posted July 11, 2012 Yeah I get what ya mean just thing is there like £13 each :/ Quote
_shaun_ Posted July 11, 2012 Posted July 11, 2012 if its the dome ones i think your talking about i have one u could have to try and see if u could mod it to fit Quote
A L 3 X Posted July 11, 2012 Posted July 11, 2012 Thats a fair point mate, well basically what i did was carefully peel the logo form the cap, then cut a center out of the cap about 4mm smaller than the caps diameter, then i raised it and plastic welded on top, after that i stuck the logo back onto the raised bit, and filled the gap with some black sealant neatly, can't tell unless your in the know Quote
Chand Posted July 12, 2012 Author Posted July 12, 2012 That's sounds awsomeBut I ant got the patients for all that lol Unless you could make me some possibly? Or was it the dome ones you used and modified? Quote
A L 3 X Posted July 12, 2012 Posted July 12, 2012 It was just the flat ones mate that come with standard grids, i could make you some yeah? Quote
Chand Posted July 12, 2012 Author Posted July 12, 2012 You could make me some? But you need a set of flat dome caps though? Quote
A L 3 X Posted July 12, 2012 Posted July 12, 2012 Yeah, I only have the set that came with mine but if you had some I could mod them to fit yours mate. Quote
Chand Posted July 12, 2012 Author Posted July 12, 2012 Right ok mate thanks Il keep an eye out then and try get hold of another set lol Thanks again Quote
Whitenoize Posted August 1, 2012 Posted August 1, 2012 Had the same problem fitting my grids today 5 mil spacers worked a treat mate Quote
