Beastmode panda Posted July 8, 2012 Posted July 8, 2012 Having ALOT of trouble with getting my bc up and running, it's wired in etc, but it came off an evo before boosting at 1.8bar and obv i dont wana do that.Just wondering HOW i can totaly re set everything!? I've asked and asked but no body will do it or even knows how to do it. The online instructions are pretty lame and confusing really.Anyone from the kent area who can do this for me!?!?! PLEASEEEEEEEEEE Quote
td04 glanza Posted July 8, 2012 Posted July 8, 2012 Hopefully you get it sorted mate I've heard the gizzmo bc's are a mare sorry i can't help! Quote
Beastmode panda Posted July 8, 2012 Author Posted July 8, 2012 i hope so too man .. such a ball ache all i want is it re-set! wish there was a master re-set button!! Quote
TrisK Posted July 8, 2012 Posted July 8, 2012 Ok. So plug it in. Then a 1 will flash then show a boost setting then go to 0.00You hold the top button and put this (the duty cycle down to say 20)Then don't press anything it'll go back to 0.00Then hold bottom button and out this (the gain) down to say 10)Then don't press anything it'll go back to 0.00 This is setting one reset. Then tap the top button. It'll go up to setting two. Do the same and put them all backDo this for all. Then reset it back upIf you need instructions on a simple how to set it up I can link you Quote
Beastmode panda Posted July 9, 2012 Author Posted July 9, 2012 Awsome man i will try it today! Does the engine have to be running and does it have to be plugged on to the actuator and turbo in order to be able to change the duty cycle and gain? Quote
TrisK Posted July 9, 2012 Posted July 9, 2012 The ingitiOn has to be on to be on so the unit has power. But that's it I think Quote
Beastmode panda Posted July 9, 2012 Author Posted July 9, 2012 thanks mate will pm you if i have any troubles! cheers. Quote
