sosolid Posted July 9, 2012 Posted July 9, 2012 is der a way to clean the carbon deposits inside a 4efte glanza engine. the car is a 96 so its probably got desposits isn't it. is der any fluids anyone has used dat will clean the inside of the engine without damaging the internals and give better emissions? Quote
StuDoc 72 Posted July 9, 2012 Posted July 9, 2012 You can use an oil flush when changing the oil but its not really recommended to be used on turbod engines. Quote
metalmickey0 Posted July 9, 2012 Posted July 9, 2012 Just blast it down the motorway. That`ll clean the crap out. A car mechanic i know told me to it also before your mot. Quote
Starlet__SR Posted July 9, 2012 Posted July 9, 2012 http://www.seafoamsales.com/sea-foam-spray.htmlDay Quote
AdamB Posted July 9, 2012 Posted July 9, 2012 If the car has always been run on 99 fuel or higher there won't be much deposits. Quote
Flaminsam Posted July 9, 2012 Posted July 9, 2012 Also be careful, them carbon deposits could be holding your engine together. A lad at work ran a flush through his engine and lost compression soon after. As adam just said if the car is ran on premium unleaded then there shouldn't be much in the way of deposits. Also regular servicing helps. Quote
Starlet__SR Posted July 9, 2012 Posted July 9, 2012 Not to mention a good thrash every now and then.Day Quote
AdamB Posted July 10, 2012 Posted July 10, 2012 (edited) Carbon deposits in the engine are very bad, and tbh are probably best left alone. Breaking off a deposit can create a hot spot in the cylinder and will cause pre-ignition, destroying your engine in very few miles. Unless the engine is going to be stripped, cleaned and rebuilt I would leave it alone. Edited July 10, 2012 by AdamB Quote
H_D Posted July 10, 2012 Posted July 10, 2012 Redex is pretty goodRedex is just a fuel system cleaner.Whatever you do, do not flush your engine as the deposits can block your sump strainer which will restrict oil flow causing further damage. Quote
