TrisK Posted July 9, 2012 Posted July 9, 2012 My mate has had white smoke and stutteringSo got him to do a compression testHe got (in bar)1: 9.72: 8.63: 7.84: 8.2What do you guy make of that? Basically after a ragging till smoke white and thick after stopping for 30 seconds then clear and be fineHe also claims its flat boosting although his guage is showing a solid 1 barWhat do you guys think?Results seem a bit all over the place Quote
AdamB Posted July 9, 2012 Posted July 9, 2012 Probably headgasket mate, they are all over the place. Did he do a wet test? Dropping oil down the bores to eliminate the rings. Quote
Flaminsam Posted July 9, 2012 Posted July 9, 2012 As a rule of thumb I always go for if there's a difference of over 1 bar across all four cylinders there must be something wrong. Do you have access to a bore scope? That would give a better indication of the problem. Quote
corofin12345 Posted July 9, 2012 Posted July 9, 2012 (edited) cylinder one seems fine, other 3 seem to have problems... if he didnt do it the way below tell him to do it again just to make sure..warm engineremove king lead "removes spark"remove EFI fuse "removes fuel"WOT "wide open throttle while cranking for comp reading" Edited July 9, 2012 by corofin12345 Quote
