Max9650 Posted July 20, 2012 Posted July 20, 2012 Hey just wondering if this is correct, wanted to see if my spool time was correct today so i put it in 5th gear at 40mph, at 2000 rpm, put my foot to the floor and i didnt get full boost ( 0.8bar) until 4500 revs, is that correct or do i have a boost leak? Cheers! Quote
pick1 Posted July 20, 2012 Posted July 20, 2012 Sounds a little high for me mate rpm wise put u were in 5th and it is only a 1.3 engine so 40 in 5th might be asking a bit much try 3rd gear or summit n see then but that's just my opinion mate some one else may be able to give u better advice Quote
Amjad Posted July 21, 2012 Posted July 21, 2012 Sounds very high, I don't know an exact figure but I'm pretty sure I get 1.1bar below 3k Quote
Max9650 Posted July 22, 2012 Author Posted July 22, 2012 (edited) 3k as in like 2-5k rpm = 3k ? maybe ill take the bumper off tomorrow and make sure everything is nice and tight Edited July 24, 2012 by Max9650 Quote
starletburkie Posted July 22, 2012 Posted July 22, 2012 should be getting .8 bar at around 2800rpm, in 5th floored from low revs Quote
AdamB Posted July 22, 2012 Posted July 22, 2012 Should be tested in 4th gear as this is a 1:1 ratio between gearbox output speed and road wheel speed. Quote
Max9650 Posted July 24, 2012 Author Posted July 24, 2012 Okay ive done the test in 4th gear and simular results, put my foot down at 2k RPM and it didnt go full boost till over 4k ,ive had a quick look at the pipes and tightened some up and it doesnt appear to made a difference,Had a look at the HKS Actuator and it appears very stiff to move by hand so im not sure if thats causing it? Quote
AdamB Posted July 24, 2012 Posted July 24, 2012 It might be stiff because it has the pin in it which secures it and stops it from moving.If there are no vac leaks it could be a problem with the actuator not keeping the wastegate shut long enough. Quote
Max9650 Posted July 24, 2012 Author Posted July 24, 2012 it seems to boost okay up till 0.5bar then it holds there for abit then continues up slowishly to 0.8 Quote
WallaceGlanza Posted July 24, 2012 Posted July 24, 2012 The HKS actuator should be stiff. It may well be set at 0.5bar and is actually creeping up to 0.8bar, what other mods have you got? Quote
Max9650 Posted July 24, 2012 Author Posted July 24, 2012 Blitz DecatAVC-R Boost ControllerHKS SSVQHKS FCDFuel Pressure RegualtorHKS Actuator (0.8Bar)HKS Silent-Hi Power ZaustBraided HosesMagnecor Leads3 Pod Guage on dashFront Mount ICRelocated Air Filterit was RR at 165 At the wheels so i dont think its set to 0.5 ... the AVCR Boost controlller says 0.8bar Quote
pick1 Posted July 24, 2012 Posted July 24, 2012 I had a similar problem once and I had the same issue and it was down to the actuator sticking which didn't allow me full boost till 4k or just over take it off mate give it a clean and see if u can free it up I'm pretty sure Starbo Moorley had a similar issue with a ct9 set up and that was down to actuator I think Quote
pick1 Posted July 25, 2012 Posted July 25, 2012 Give it a little soak or heavy spray of wd40 mate then just work it in mate moving the actuator arm etc to free everything up then see how u get on dude Quote
pick1 Posted July 25, 2012 Posted July 25, 2012 My mistake then just sounded about rite when I wrote it may of been a different issue i had then but sure Starbo Moorley had a similar issue and it was down to the actuator I dunno then mate keep trying lol Quote
Max9650 Posted July 25, 2012 Author Posted July 25, 2012 My mistake then just sounded about rite when I wrote it may of been a different issue i had then but sure Starbo Moorley had a similar issue and it was down to the actuatorI dunno then mate keep trying lol Moorley gave me a PM saying : Hi mate, if you disconnect the actuator from the wastegate end (usualy nut and bolted on or has a r clip through it) you should be able too pull it and feel the spring working. i just gave mine a good tugging and that sorted itIve pm'd him back as i dont quite understand which bolt to undo - its a hks actautor, im not sure if he ment the bolt on the bracket or what.Cheers all Quote
Max9650 Posted July 25, 2012 Author Posted July 25, 2012 (edited) Okay i've done what Moorley said and i feel it picks up boost abit faster but still seems to have the problemIve made 4 videos, but i was driving 1 handed as i had the camera in my left hand which i also needed to change gear, so did my best haha Edited July 27, 2012 by Max9650 Quote
Max9650 Posted July 26, 2012 Author Posted July 26, 2012 What do u think peeps? Was revving the car on idle up to like 5k and the actuator arm wasn't moving, is this normal? Quote
