ali_legend Posted July 29, 2012 Share Posted July 29, 2012 (edited) Hi guys, as Afew of you know I have recently purchased an ek4 and need abit of camber adjustment advice. Suspension is pretty much the same with most cars so the car is irrelevant really. Ok before I start, no vtak jokes! Especially amjad! LolOk I have BC coilovers and rolling with Josh's ex alloys. Which are pretty wide. Anyway I'm just after abit off camber but can't justify paying for camber arms etc.. Just to gain abit of camber. Is there anything you guys can recomend? Thank you Edited July 29, 2012 by ali_legend Quote Link to post Share on other sites
Amjad Posted July 29, 2012 Share Posted July 29, 2012 Just thought I'd mention his BCs don't appear to have adjustable top mounts for camber. Dunno if they're adjustable anywhere else on the shock unit aside from the regular bolts like OEM.. Quote Link to post Share on other sites
ali_legend Posted July 30, 2012 Author Share Posted July 30, 2012 Yh as amjad said they don't have camber adjust from the top mounts. Quote Link to post Share on other sites
Asad Posted July 30, 2012 Share Posted July 30, 2012 If the stock setup and you rear lca's are maxed out i dont see any other way of doing that doesnt involve something dodgy....did you get cheaper bc's which dont have camber adjustment or do they not do them? id put your fanblades back on till you can afford the camber arms, then do it properly...looks aside how does she drive? Motorway speeds? You thought of tyre wear too? Quote Link to post Share on other sites
ali_legend Posted July 30, 2012 Author Share Posted July 30, 2012 On 7/30/2012 at 9:17 AM, Asad said: If the stock setup and you rear lca's are maxed out i dont see any other way of doing that doesnt involve something dodgy....did you get cheaper bc's which dont have camber adjustment or do they not do them? id put your fanblades back on till you can afford the camber arms, then do it properly...looks aside how does she drive? Motorway speeds? You thought of tyre wear too?Nope unfortunately for civics the bc's don't have camber adjustment. She drives nice mashallah. No rubbing or anything tbf. Steering feels lighter but that's probably because of the coilovers and LCA's. I might just get the car aligned and hope he can et abit of camber out of how it is now. Quote Link to post Share on other sites
morgey Posted July 30, 2012 Share Posted July 30, 2012 Ek's run a twin wishbone setup, you need to purchase some camber adjustable upper wishbones, d2 skunk2 racing and the likes make them. If you look in front arches they are the Y shaped brackets that the shock goes thru near the top, they have a ball joint on them. The rears you can buy adjustable camber arms from the same companys, or you can put washers under the mounting point. If you need lots of adjustment this wont work or you will have to get longer bolts ;)Dont buy cheap as they dont last ;) Quote Link to post Share on other sites
morgey Posted July 30, 2012 Share Posted July 30, 2012 Front camber and rear ek camber kits ;)/>http://www.funkypower.com/catalogue.php?make=HONDA&model=CIVIC&year=1996-00+CIVIC&level1=SUSPENSION+%26+STABILITY&level2=CAMBER+CORRECTION+KITS&man= Quote Link to post Share on other sites
ali_legend Posted July 30, 2012 Author Share Posted July 30, 2012 On 7/30/2012 at 12:02 PM, morgey said: Ek's run a twin wishbone setup, you need to purchase some camber adjustable upper wishbones, d2 skunk2 racing and the likes make them. If you look in front arches they are the Y shaped brackets that the shock goes thru near the top, they have a ball joint on them. The rears you can buy adjustable camber arms from the same companys, or you can put washers under the mounting point. If you need lots of adjustment this wont work or you will have to get longer bolts ;)Dont buy cheap as they dont last ;)Thanks for reply matey. I'm only after abit of camber. Is there no way of gaining slight camber withought going for the full amber kits? Quote Link to post Share on other sites
morgey Posted July 30, 2012 Share Posted July 30, 2012 Lower it within an inch of the floor? LolOther than that, Not that i know of. You can get cheaper kits than that £50 or so but my mate went thru 2 sets within a month, then brought skunk2 ones and never had a problem upto the point he sold his car a year later Quote Link to post Share on other sites
ali_legend Posted July 30, 2012 Author Share Posted July 30, 2012 On 7/30/2012 at 4:10 PM, morgey said: Lower it within an inch of the floor? LolOther than that, Not that i know of. You can get cheaper kits than that £50 or so but my mate went thru 2 sets within a month, then brought skunk2 ones and never had a problem upto the point he sold his car a year laterAhhh damn lol what to do?!??? Quote Link to post Share on other sites
Amjad Posted July 30, 2012 Share Posted July 30, 2012 Those rear ones are an okay price but the front ones Quote Link to post Share on other sites
ali_legend Posted July 31, 2012 Author Share Posted July 31, 2012 On 7/30/2012 at 10:59 PM, Amjad said: Those rear ones are an okay price but the front ones Ini man! I can get rears for £30 brand new. But fronts are flippin expensive man!!!!! madness Quote Link to post Share on other sites
