jbird Posted August 1, 2012 Posted August 1, 2012 How much are you expected to see the TTE sprin from an sr drop a bag standard starlet? Quote
LukeSR Posted August 1, 2012 Posted August 1, 2012 25mm I think they are!Which isn't low enough imo! Quote
jbird Posted August 1, 2012 Author Posted August 1, 2012 True, but should be fine untill coilovers. Quote
morgey Posted August 1, 2012 Posted August 1, 2012 I found them fairly desent for stock springs tbh nice and progresive so comfy but resonable handling, i think sr's have better shocks than most uk starlets aswel tho ;) Quote
PaulStarletSR Posted August 2, 2012 Posted August 2, 2012 tis true there only 25mm lower than standard but combined with a stiffer shock only on SRs and they handle fairly well but i wud go for 40mm springs and itl handle like a train on rails with the ryt tyres Quote
SRchris Posted February 25, 2014 Posted February 25, 2014 Having owning an SR and a normal starlet,I drive it regularly enough to feel how the car reacts......SR.... Steering feels very positive compared to the normal starlet, still has lot of body roll but a lot less than it's lower models. You can feel every bump in the road, i drive my sr avoiding ridges and pot holes as they are rediculoysly bad! When turning sharp and accelerating it feels like the wheel wants to turn in more, giving you feedback to let off the throttle (under steer). The normal starlet feels like it's a spring retaining it asthough it wants to be straitened up.Solidia or any non sr starletFeels....wank... Steering feels loose and when it does turn you have the body roll to follow, cornering hard.. Back end goes really light and a lot of lift off oversteer, feels in some what way unpredictable compared to the SR ( or that may be because I drove my SR more and trusted it) Again you have to consider tyres.... Starlets have stupidly thin things where the SRs have 195s not massively wide but make a lot of difference in traction and handling! Quote
Di_Bodi Posted September 5, 2015 Posted September 5, 2015 Would anyone please check what is the number printed on them tte springs? Is it AM 27015 HA (rear) and AM 27015 VA on fronts?!? Thanks in advance! Quote
Di_Bodi Posted September 9, 2015 Posted September 9, 2015 27015 rears27014 fronts Thank you again morgey!!! Quote
