whats the best rev limiter to get
Do you mean delimiter for speed cut? Because oem ecu has built in rev limit dude if you want to raise it you need management and idealy some head and bottom end mods
Edited by shorty
I dont get why you would need to use one tbh dude. as without mods if you raise the limit you risk of coil bind :( and if you have mods then a piggy back or standalone as you will get more benifit.
