hazell ep91 sr Posted August 10, 2012 Posted August 10, 2012 Engine is in and all wiring is done etc. It wont start. First it had no fuel but fixed that by finding an enearthed wire from fuel pump. But ive got no spark? From niether pluga or king lead. Any ideas people? Helppp Quote
hazell ep91 sr Posted August 10, 2012 Author Posted August 10, 2012 Does it need to be? Bolt it onto body? Quote
hazell ep91 sr Posted August 10, 2012 Author Posted August 10, 2012 Done and it Runs. Bad news is engine is fucked. White smoke and loud tapping sorta sound. Will try and get video up later. All that work for nothing Quote
LukeSR Posted August 10, 2012 Posted August 10, 2012 Done and it Runs. Bad news is engine is fucked. White smoke and loud tapping sorta sound. Will try and get video up later. All that work for nothing What!? I bet your gutted Did you not see it running when you bought it? Quote
hazell ep91 sr Posted August 10, 2012 Author Posted August 10, 2012 I am. Nope got it off zeldos who got it from gt bitz supposedly. He payed over a grand for it. Oh well. Need to find out what is fucked and rebuild engine i suppose.....Fuck Quote
Asad Posted August 10, 2012 Posted August 10, 2012 Did you fit the throttle body pipes the right way round?? Quote
Asad Posted August 10, 2012 Posted August 10, 2012 http://www.toyotagtturbo.com/forums/showwiki.php?title=Throttle+Body+PipesIf they are wrong, drop the oil and coolant and run some fresh stuff thru then drop it again just to be sure... Quote
kingo228 Posted August 10, 2012 Posted August 10, 2012 Done and it Runs. Bad news is engine is fucked. White smoke and loud tapping sorta sound. Will try and get video up later. All that work for nothing sorry to hear that dude, dont give up its worth it in the end !! Quote
hazell ep91 sr Posted August 10, 2012 Author Posted August 10, 2012 So asad the white smoke could just be water vapour? I wont give up Quote
micky boy Posted August 10, 2012 Posted August 10, 2012 Asad always talkes sence Hope it is the pipes mate and yes it could just be water vapour Quote
hazell ep91 sr Posted August 10, 2012 Author Posted August 10, 2012 Fingers crossed.. still a bit confused whats supposed to go where lol Quote
Asad Posted August 10, 2012 Posted August 10, 2012 Could be that youve mixed the pipes up and waters got in (youd be surprised how many trained people do this), can check and see mate fingers crossed thts all it is....let us know how you get on buddy Quote
micky boy Posted August 10, 2012 Posted August 10, 2012 Haha yeah it can be abit tricky if you dont know how.If you want mate ill take a few pics of my throttle body etc tomorrow and see if that help? Quote
Asad Posted August 10, 2012 Posted August 10, 2012 If your confused about the water pipes loop them up so they dont run thru the throttle body Quote
hazell ep91 sr Posted August 10, 2012 Author Posted August 10, 2012 But would that explain the noise? Will run compression test tomorrow too. Some pics would help too. I think the vacuum pipes are blocked off as someone know with a glanza said they werent needed? Quote
Asad Posted August 10, 2012 Posted August 10, 2012 Dont worry mate, gets some pics up/check things over tomorrow with a fresh head Quote
hazell ep91 sr Posted August 10, 2012 Author Posted August 10, 2012 Yeah will doThanks for all the help so far guys! Quote
hazell ep91 sr Posted August 11, 2012 Author Posted August 11, 2012 Inlet hoses are fine. The white smoke stinks. Just like my dads rover v8 in his ac cobra kit car and his piston rings seized. God knows whats wrong. Feel proper deflated now and struggling to even find a rounaround car for the meantime. Quote
Asad Posted August 11, 2012 Posted August 11, 2012 Does it just smoke on idle? Or when you rev it? Have you dropped the oil out? The noise? Quote
hazell ep91 sr Posted August 11, 2012 Author Posted August 11, 2012 Smokes most when i rev it. Brand new oil in there before i started it. Engine had no oil in before i put it in. And noise is still there. Sounds like a diesel. Defo running on 4 cylinders. Quote
hazell ep91 sr Posted August 11, 2012 Author Posted August 11, 2012 Nope.header and radiator level hasnt moved. Quote
