Starbuck Posted August 14, 2012 Share Posted August 14, 2012 I wish to change the PS hoses to coloured ones. Anything I should look out for or just take them off and put them on? Quote Link to post Share on other sites
james@cjperformance Posted August 14, 2012 Share Posted August 14, 2012 drain it first and just swap them over I would advise new clips allround though Quote Link to post Share on other sites
Starbuck Posted August 14, 2012 Author Share Posted August 14, 2012 Next question, how do I drain it? LOL Just pull hoses off and drain into pot, reattach new ones and refill? Also can it be reused? Quote Link to post Share on other sites
james@cjperformance Posted August 14, 2012 Share Posted August 14, 2012 personally id drain it from the rack as you will get it all out and I wouldn't re use it either Quote Link to post Share on other sites
Lukew360 Posted August 14, 2012 Share Posted August 14, 2012 I pulled my hose off and had a pot ready to catch the fluid quick, re-used my fluid to with no problems ;) Quote Link to post Share on other sites
Starbuck Posted August 20, 2012 Author Share Posted August 20, 2012 So what hoses can be changed with minimal fuss? As in pull off and put on. Quote Link to post Share on other sites
StuDoc 72 Posted August 20, 2012 Share Posted August 20, 2012 I didnt even drain mine i managed to chage the powersteering ones without losing much at all. The water ones you will have to drain the system. And the ones at the back of the engine if like mine have never been off before are a fucking nightmare. Also you need to remove the starter motor to do the short dumpy water one. Although its only 2 bolts.To answer your question the only 1s that are minimal fuss are the 1or2 if you have a gt for the brake servo. The rest require the draining of fluid and stuff. Quote Link to post Share on other sites
Starbuck Posted August 20, 2012 Author Share Posted August 20, 2012 So the brake servo ones on the back can be whipped off without anything coming out? Quote Link to post Share on other sites
StuDoc 72 Posted August 20, 2012 Share Posted August 20, 2012 Aye those are just vac pipes Quote Link to post Share on other sites
Starbuck Posted August 20, 2012 Author Share Posted August 20, 2012 Cheers Quote Link to post Share on other sites
Bluebear Posted August 20, 2012 Share Posted August 20, 2012 Is it the powersteering pipes that need to have that special lining on the inside of them? Quote Link to post Share on other sites
StuDoc 72 Posted August 20, 2012 Share Posted August 20, 2012 All pipes that carry fluid should have a special ply on them Quote Link to post Share on other sites
james@cjperformance Posted August 20, 2012 Share Posted August 20, 2012 On 8/20/2012 at 11:17 AM, StuDoc 72 said: All pipes that carry fluid should have a special ply on themOnly ones that carry oil need specila linings on. Our hoses have the lining on all of them though Quote Link to post Share on other sites
