Pridzz Posted August 15, 2012 Posted August 15, 2012 Changed to a braided and didnt do gasket. Obviously leaking like a bitch.Put new gaskets on and still leaking! On the banjo side I put a copper washer eitherside. Is that correct or is it just 1washer?Wasnt leaking before I put new feed on so I assume its that. Changing gaskets last night has made it worse so I can only assume thats it.. Quote
akyakapotter Posted August 15, 2012 Posted August 15, 2012 shit man i feel bad now which end is it coming from tom ? banjo or the other end Quote
Socks Posted August 15, 2012 Posted August 15, 2012 leaking from banjo bolt or the face to the turbo? Quote
Pridzz Posted August 15, 2012 Author Posted August 15, 2012 Bango end for definate, Looking at the washer you can see oil. Need to get under to check turbo side when not raining. Its dripping along the sump but its only happened since changing the feed Quote
Johnboy GT Posted August 15, 2012 Posted August 15, 2012 (edited) You have dowty washers on your banjo bolt?I can see how that would work actually!John Edited August 15, 2012 by Johnboy GT Quote
