Pridzz Posted August 15, 2012 Share Posted August 15, 2012 Changed to a braided and didnt do gasket. Obviously leaking like a bitch.Put new gaskets on and still leaking! On the banjo side I put a copper washer eitherside. Is that correct or is it just 1washer?Wasnt leaking before I put new feed on so I assume its that. Changing gaskets last night has made it worse so I can only assume thats it.. Quote Link to post Share on other sites
akyakapotter Posted August 15, 2012 Share Posted August 15, 2012 shit man i feel bad now which end is it coming from tom ? banjo or the other end Quote Link to post Share on other sites
Socks Posted August 15, 2012 Share Posted August 15, 2012 leaking from banjo bolt or the face to the turbo? Quote Link to post Share on other sites
akyakapotter Posted August 15, 2012 Share Posted August 15, 2012 I have 2 of these bad boys on mine Quote Link to post Share on other sites
Pridzz Posted August 15, 2012 Author Share Posted August 15, 2012 Bango end for definate, Looking at the washer you can see oil. Need to get under to check turbo side when not raining. Its dripping along the sump but its only happened since changing the feed Quote Link to post Share on other sites
Johnboy GT Posted August 15, 2012 Share Posted August 15, 2012 (edited) You have dowty washers on your banjo bolt?I can see how that would work actually!John Edited August 15, 2012 by Johnboy GT Quote Link to post Share on other sites
