P44YNE Posted August 15, 2012 Posted August 15, 2012 Is it possible to remap the standard ECU?...and if so, can it have an overrun style map to make loud backfires between gear changes and when slowing down VXR style-ish ... and if not, is there an ECU standalone or piggyback that could be programmed in this way? Quote
Stu Posted August 16, 2012 Posted August 16, 2012 Not easily - the chip is soldered to the board making removal pretty tricky and even then you'd have to decifer the coding to change it Quote
jtaylor1990 Posted August 16, 2012 Posted August 16, 2012 Stock ECU is unmappable i believe, well thats what I was told by a guy that can "map any car"....yh my arse lol false advetisment Quote
Socks Posted August 16, 2012 Posted August 16, 2012 Stock ECU is indeed not mappable...Piggyback for upto 300bhp.. but ideally standalone is always best! Quote
