Me and a friend just fitted a new hks actuator on his gt it's set up at 9psi low boost and I think about 13-14 psi on hi . He hasn't tried it on hi yet as he is scared it's goin to blow up or something . I'm pretty sure it won't but can someone post something to 're assure him please .
Fuel cut differs on every car, only way to find out where his is, is to go and test it out :) not a big deal if you hit it once just wind the actuator a bit until you have found where its safe! So long as you don't keep hitting it you shall be fine :D
Lmao 14psi is basicaly 1bar you will defo hit fuel cut especialy with the mods he has!! fuel cut is around .85bar and it will hit more on a cold day to a hot day as air is denser on a cold day. tbh id set it to .6low .8hi and leave it alone till you have the proper supporting mods for 1bar! You will shit the 3rd piston if you run too much boost atm as you havnt said your running an uprated exhuast manifold so the oem restriction will be in place on the third runner. supporting mods befor boost!! Simples!
