scoobykilla Posted August 24, 2012 Posted August 24, 2012 Well i thot i would quickly through on my new exhaust mani last night after work, so set about removing everything and preping everything for putting back on. After a while i had the new mani on, gave the car a refill of oil and started it up..............putt putt putt putt.......Its blowing at the exhaust mani gasket (bottom right).I put a new gasket on when i fitted the new mani and cleaned all surfaces so it shouldn't b blowing.What should i do folks?I know the best thing to do would be take everything off again but its so time consuming. Quote
mark1991 Posted August 24, 2012 Posted August 24, 2012 what manifold have you got? if its a toyosports they like to wrap with heat fir they dont seal right. if its a ct9 your running i have a oem cast manifold all nicly ported £20 ;) Quote
scoobykilla Posted August 24, 2012 Author Posted August 24, 2012 Ye its a toyosports :S. Aye av got a oem ported mani in the workshop but like the look of an upgraded one lol. Are toyosports ones that shit lyk lol? Quote
Idrees Posted August 24, 2012 Posted August 24, 2012 Yeah they are rubbish, Oem ported ones are better IMO If you're using one of that bogus 'racing' gaskets supplied by Toyosports that won't help either Quote
scoobykilla Posted August 24, 2012 Author Posted August 24, 2012 Awryt, what a waste of money GRRROwell think i've got myself a second hand silkroad mani, been told they are pritty good, so hopefully i wont have any problems with it Quote
Taggy Posted August 24, 2012 Posted August 24, 2012 Yeah here is the problem, the idiots at toyosports have made the gasket to small, it doesnt fit properly Quote
akyakapotter Posted August 24, 2012 Posted August 24, 2012 Yep Toyo sports gaskets do this they are crap Quote
scoobykilla Posted August 24, 2012 Author Posted August 24, 2012 Thats shit.So do you think the manifold will b ok if i stick on a toyota oem gasket or will i be better sticking the second hand Silkroad Manifold i am getting on? Quote
akyakapotter Posted August 24, 2012 Posted August 24, 2012 Should be fine with oem but won't be long till the Toyo Mani cracks. mine cracked within a month so ported my oem Mani and was spot on till I took it off 1 year later. Quote
scoobykilla Posted August 24, 2012 Author Posted August 24, 2012 awryt cheers, mite try the silkroad one, its second hand but suposed to be pritty good Quote
