russ78 Posted September 10, 2012 Posted September 10, 2012 I bought a grounding kit which has 6 grounding wires do i use all these ? And where are all these going ???It has a L shaped mounting bracket for the battery so do i take the stock one off if i do this how do i mount the L shaped bracket any help would be greatthanks Quote
JayJ Posted September 19, 2012 Posted September 19, 2012 Remove stock one and use l-shaped one. you can use all the six wires for better earth. Check TGTT thread for some mounting points. Quote
