I'd imagine 1 ltr would be enough mnaybe get 2 to be on the safe side and just do the clutch aswell while your at it. Are you on draining out the old stuff and replacing the whole lot i assume?
I wouldn't drain the system "dry" as you'll have loads of fun with air pockets, best bet is to get 99% of the old fluid out of the reservoir with a syringe, top up with the fresh stuff, THEN then bleed each corner until you see fresh fluid.
If you use a coloured fluid like Ate Blue(/red/yellow etc) it makes the job easier!
Is that the best way then keri rather than emptying as said or will it cause problems with using dot 5.1 as its not been changed since I got it as a pretty much fresh import last year?
And ah I see, where do I get this coloured stuff local lol?
Its all dependant on how you will do it and how long you have. Draining it will take longer but will give you a better clean through as your not mixing the fluids. Like Keri said tho if you do it that way will save you with air pockets and will be far less hassle.
Bare in mind though if the car has had the same fluid in it all its life thats 13+ years and brake fluid absorbs water so there tends to be a heavy slime a bit like imulsified oil that gathers in the bottom of your resivoir If you want to get rid of this the only way is to drain the system completely and detaching the flexi from the calipers to avoid getting the gunge stuck in the calipers when bleeding.
Edited by StuDoc 72
Nice one I shall do that then if it's gonna save a lot of hassle, or is the other way easy enough?
Also if I'm replacing the lines with braided ones, am I best replacing a hose,
Bleeding that corner then moving on or replacing all then bleeding through all? I'd assume the latter
Yeah Keris way is definatly the best way,i did a full bleed and i had loads of issues with 'air pockets' causing me to loose the brake pedal a few times.
Ah right, don't wanna be doing that then, out of interest how is it you actually drain the full system?
Also, how will i be best changing the lines and bleeding then, will this create air pockets?
