  • 5 months later...
is it worth buying tho Im planning on dressing engine bay up buying all the parts getting them powdercoated all in the same colour and doing a weekend on fitting it all as a braking point of veiw is it worth it or as cosmetic is it worth buying
I had problems with mine mate couldnt get it to line up think its due to the engine mount bolt being to long seen some people put a few washers to pack the bolt out a bit then it fit fine its up to you if you get one bud :)
Personally I wouldn't recommend them. I had one fitted to the Glanza and had to take it off as I felt it was dangerous. The brakes were perfect before fitting, after fitting it the pedal wouldn't engage as far as before it was a weird kind of feeling in the pedal. Anyway this resulted in very soft braking, not good doing over 240kmh in a Glanza! lol! I took it out and it was fine again afterwards. Some friends of mine in lower powered cars have it and think its fine, a very worthwhile upgrade, maybe it was the force of braking at such high speeds in my car that it didn't work as it should
