starletgt.neal Posted September 14, 2012 Share Posted September 14, 2012 hi guys were doing a turbo conversion at the moment and we wernt sure if the standard glanza system fits the n/a or wether you need a custom exhaust? if the glanza exhaust fits straight on or just needs minor mods thats ok otherwise it would be easier to get a custom exhaust i think Quote Link to post Share on other sites
morgey Posted September 15, 2012 Share Posted September 15, 2012 From about the bottom of the fire wall back they are the same but anything infront ie visable from the engine bay without the engine in place isn'tBut ep82 and 91 backbox hangers are different from one another but can be modded to fit each other quite easily Hope that helps Quote Link to post Share on other sites
starletgt.neal Posted September 15, 2012 Author Share Posted September 15, 2012 brilliant so they hang exactly the same then so when i have my 4efte in place the standard glanza exhaust will just hang straight on the hangers and bolt up to my decat no problem then? Quote Link to post Share on other sites
Rob H@RCH Engineering Posted September 16, 2012 Share Posted September 16, 2012 No there not the same, the N/A has the front hangers on the rear gear box mount and only one in the center of the car thats used as a earth strap or something, The glanza has non on the gear box mount and 2 mounts in the center of the car. I welded an extra mounting in the center of the car to mount my glanza Blitz nur spec to but it would work with out it. The one on the left of the pick is the one I had to weld on. Quote Link to post Share on other sites
starletgt.neal Posted September 16, 2012 Author Share Posted September 16, 2012 cool thankyou very much mate so it will fit perfect just need to weld that one bracket in the centre thanks again rob Quote Link to post Share on other sites
Rob H@RCH Engineering Posted September 16, 2012 Share Posted September 16, 2012 yep it will fit fine you dont have to weld on the hanger but it does make it better and it stops the exhaust from twisting. Quote Link to post Share on other sites
