A L 3 X Posted October 9, 2012 Posted October 9, 2012 (edited) Seems to be since I've had full alignment done properly but I may have just noticed it then, occasionally when stopped and turning or moving slowly and turning say to reverse into a parking space I get a slight kling noise like the spring is turning but looking at the coilover nothing appears to be amiss so any idea what could cause it? Edited October 9, 2012 by A L 3 X Quote
ryan lang Posted October 9, 2012 Posted October 9, 2012 make sure the locking collars are done up tight dude Quote
morgey Posted October 9, 2012 Posted October 9, 2012 check to see if the bracket that holds the brake line on the shock isn't catching the bracket on the car where it goes from hard pipe to the flexi, you may need to get some one to go from lock to lock whilst you lay under the car and look. oh and dont jack it up you need the weight of the car on the coilovers( i had this problem on my BC's, not sure if meisters do aswel) Quote
StarletMad Posted October 9, 2012 Posted October 9, 2012 I've also read somewhere long the way something regarding the above ^^^ Quote
A L 3 X Posted October 9, 2012 Author Posted October 9, 2012 I recently changed my brake lines to braided and moved them lower down as they were rubbing and caused it to almost split both my brake pipes Will check if either of these are the issue when im off Cheers Quote
morgey Posted October 9, 2012 Posted October 9, 2012 (edited) Mine munched through my braided set mate so if you've got 30secs have a quick look and see if theres any damage, if there is then thats most likely your problem! Altho u say you've moved them so it might just be the bracket catching. Edited October 9, 2012 by morgey Quote
A L 3 X Posted October 16, 2012 Author Posted October 16, 2012 Yeah I've been keeping an eye they seem to be ok but Ima look again this weekend also lol Quote
MeisterR Posted November 1, 2012 Posted November 1, 2012 Just browsing the forum and notice this.Cannot stress the above enough is the check the brake line clearance.When lowering the car, the bracket on the damper is possible to catch onto the chassis brake line bracket within the turning circle.Should that happen bent the bracket out of the way to make sure nothing make contacts.This is part of the safety checks that should be done to make on every MacPherson Strut suspensions.We have made a small revision by changing the angle of the brake bracket on the damper, but it doesn't guarantee anything as this is base on the ride height adjustments.Please do make sure that nothing is making contact, as this can be a serious issue when things goes wrong.If you have any have any concerns, please feel free to E-mail me at info@meisterr.com and I'll be happy to help. Quote
A L 3 X Posted November 1, 2012 Author Posted November 1, 2012 Hi Jerrick, yeah I had that issue, I've since fitted braided lines and attached them to the bottom of the bracket as with them bolted I. It would always catchHasn't made any marks on the new lines and doesnt seem near or anything so assume its not rubbing now? Quote
Corey Posted November 1, 2012 Posted November 1, 2012 (edited) Hey dude check to see are lower arms rubbing off the the anti roll bar./>http://www.toyotagtturbo.com/forums/showthread.php?74491-FAO-Whiteline-front-arb-and-alk-users&highlight= Edited November 1, 2012 by Corey Quote
A L 3 X Posted November 1, 2012 Author Posted November 1, 2012 I shall check mate but I don't have an alk soDoubt it would be that? Quote
MeisterR Posted November 1, 2012 Posted November 1, 2012 Hi Jerrick, yeah I had that issue, I've since fitted braided lines and attached them to the bottom of the bracket as with them bolted I. It would always catchHasn't made any marks on the new lines and doesnt seem near or anything so assume its not rubbing now?Just get on the ground and have a friend turn the wheel lock to lock.If it isn't making contact, then it should be fine at least as far as the brake line is concern.It is just one of those safety check that should be perform as soon as the suspension are installed.But I would do it again just for a peace of mind. Quote
