Have unscrewed the 2 adjusters in the lights and its kinda pushed the headlight out but not all the way but can't get the bloody thing out! Any ideas??
I just give them one big pull sounds harsh but the best way!!! Theres like a ball joint in left hand top corner (drivers side headlight) if you pull the headlight in that corner it should pop off just go easy because the clips are temprementel
And the same go's for the Pside headlight but the ball joint will be in the top right coner
Ohh and as Luke has said take the indicators out..Also make sure the wires are disconected from the headlight befor you start pulling lol
Edited by micky boy
Take indicators out
Unclip wiring
Undo 10mm nut
Undo top clip and wiggle it until its free, be careful as they are brittle.
Undo bottom clip and wiggle free by pulling up wards just check the clips are clear and that you not going to break them.
