ali_legend Posted November 5, 2012 Posted November 5, 2012 Right guys firstly ill start with saying i have had a search through the forum but can find my exact answers. I have two routes i can take and just need advice which one to go down.I have a GT TD04, Mods - TDO4, toyosport mani and decat, Apexi exhaust, Blitz FMIC, fse FPR (abit temperamental tbh), running 0.5bar Ok the dilemmaI will get all gauges that i need because currently i dont have any, So will get boost, oil temp and oil pressure asap.1) Fit gauges, Turn boost to 0.7 bar and adjust FPR, Later get a Plug and Play ecu and turn boost to 1 bar although i here fuelling will never be perfect with Plug and Play on TD04?2) Fit gauges, Buy a boost controller, Buy an emanage ECU, Remap and run 1 bar?any advice would be much appreciated....... p.s i dont have much knowledge with boost, im a Vtec boy originally. Quote
turbo Grant Posted November 5, 2012 Posted November 5, 2012 Best bets to go for a programable ecu like emb/emu Quote
Asad Posted November 5, 2012 Posted November 5, 2012 Fit gauges, Turn boost to 0.7 bar and adjust FPR + Buy a boost controllerthen when you have money..Buy an emanage ECU, Remap and run 1 bar Quote
AdamB Posted November 5, 2012 Posted November 5, 2012 Save your money on an oil temp gauge, not really needed unless you go hammering around a track ;)I would go with the programmable management route, much safer, much better drive. Quote
ali_legend Posted November 5, 2012 Author Posted November 5, 2012 So far everyone saying emanage ecu. Can get one for about £200 so not bad. What gauges would you guys say are a must? Quote
Broony Posted November 5, 2012 Posted November 5, 2012 Be worth getting a wideband too to keep an eye on afrid go for Water +oil temp + boost To replace the shite stock gauges then oil pressure for safety Quote
AdamB Posted November 6, 2012 Posted November 6, 2012 Boost and oil pressure are the main ones. A wideband gauge will help as well, but if its been mapped properly its not something I would worry about if your on a budget.I've seen just as many engines die from oil pressure problems than I have boost/detonation related. I've had 2 engines die from oil pressure problems and its a pain in the shitter! Quote
ali_legend Posted November 6, 2012 Author Posted November 6, 2012 Right much appreciated lads.! So I'm defo getting boost, oil pressure, just deciding out of water and oil temp. So what everyone has said so far is get a boost controller, emanage and a remap and that much better over a plug and play? Quote
ali_legend Posted November 6, 2012 Author Posted November 6, 2012 Also I I bought a boost controller would I still need a boost gauge? Quote
Asad Posted November 6, 2012 Posted November 6, 2012 Oil temp imo much better indication as to when to give it a boot i.e when its nice n warm NOT when the waters hotIf it overheats youll know via poor running/oil gauges Yeah bro set it up to the max of the standard ecu 0.85/9 with supporting mods then go for a emanage with higher boost when youve got the paper Quote
Asad Posted November 6, 2012 Posted November 6, 2012 I think most display the boost reading but depends on which you get apexi avcr (expensive) and blitz (big block one) are what id recommend Quote
ali_legend Posted November 6, 2012 Author Posted November 6, 2012 Nice one bro. Yh I'll get boost oil temp and oil pressure. And a boost gauge. How about the depo boost controllers? They look very similar to a boost gauge? Quote
Asad Posted November 6, 2012 Posted November 6, 2012 No experience with them bro i prefer the tried and tested...get the blitz big block its a solid boost controller and can be had for peanuts of you look in the right place Quote
ali_legend Posted November 6, 2012 Author Posted November 6, 2012 Ok cool ill look out for one. Could that be used as a boost gauge then? Right place? Quote
ro55ifumi Posted November 6, 2012 Posted November 6, 2012 Look at the deals that TD an Racetech have on @ £550 for emange including fitting and mapping!!!Mapping alone is gonna cost you £250-£300Had mine done before i forged on the TD04 with pressure reg and standard fuel pump and injectors @ 1 bar and made 235bhp John Quote
ali_legend Posted November 6, 2012 Author Posted November 6, 2012 Hmmm them figures are wicked John.! I'd be well happy with that! I might have to do that! I have decent mods so all I need is emanage and remap, I take it they adjust fuelling and all too? Quote
ro55ifumi Posted November 6, 2012 Posted November 6, 2012 Yes mate they adjust fueling to suit mate ;)John Quote
