Ecu speed output ?
Try this link, not the clearest and im not 100% sure this is the correct diagram as i dont have a 4efte so if it looks different to yours then dont touch it and wait for a turbo junkie to help you out ;)
But on this Speed input is right plug bottom row 4 in from the left
/>http://img.photobucket.com/albums/v305/speedfreaq/fuelandignmod.gif
  On 11/11/2012 at 10:16 AM, mech5107 said:
This is the pin you need, either cluster side, or ecu side, shouldn't mater.
It's a true pulse signal, not just an on off...
Yep your right. As long as the wire isn't cut this should be fine
(Unless of course the Blitz Power Meter has a input and output wire for speed signal).
Edited by Stu
Cheers lads got it sorted yesterday it was spot on i wired the ignition live too the cd player the earth too the bracket of the ecu and the wire was spot on just snipped it in half stripped both sides the stripped the wire for the blitz twisted them all together and shot a choccy block on them thanks for the help guys :)
