Mikey Jay Posted June 28, 2007 Posted June 28, 2007 Aloha all.Right, my drivers side headlight is slightly yellowy.Is some kind of age related grime I do believe, I know it's on the outside as if you scratch at it lightly it comes off (a little bit)What's the best way to clean the light up good and proper??(read somewhere you can use t-cut??)Cheers in advance guys Quote
squeekyduck Posted June 28, 2007 Posted June 28, 2007 use T cut dude. I use T cut everyso often and it transforms the lights. They look like new again!! Last time i did it was 3 weeks ago and they are still holding up. Quote
Mikey Jay Posted June 28, 2007 Author Posted June 28, 2007 Cheers amigo.Will do that next weekend, as want the car looking as good as possible for JAE Quote
StarletRick Posted June 28, 2007 Posted June 28, 2007 i use the meguairs scrath x stuff, that works pretty well Quote
scutch0 Posted June 28, 2007 Posted June 28, 2007 fenwick's superior windowizeits for use on plastic lenses and windows, but it really works on glass too. Quote
Glanza_Ragger Posted July 1, 2007 Posted July 1, 2007 Any type of cutting compound.. I used g3 on my headlights, as they were yellow and mottled.Give it a quick wax over once youve cut the lights otherwise they will yellow again in no time ;) Quote
Glanza_Ragger Posted July 2, 2007 Posted July 2, 2007 What? With normal car wax?Yeah after youve cut it with a compound, just give it a coat of car wax, not polish.Something like meguiars tech wax will do. That sorta wax bro.They will yellow again over time but it will just delay it Quote
Mikey Jay Posted July 2, 2007 Author Posted July 2, 2007 Have the full Autoglym cleaning set, what's the best one to use from that?(if anyone else here uses Autoglym)Cheers for the help though guys ;) Quote
stu0500 Posted July 2, 2007 Posted July 2, 2007 i just use rubbing compound,i saw a post on gt turbo on how to split te ligts. im gonna take min to bits ad clean inside Quote
Glanza_Ragger Posted July 3, 2007 Posted July 3, 2007 i just use rubbing compound,i saw a post on gt turbo on how to split te ligts. im gonna take min to bits ad clean insideSplit glanza lights? I think youll probably find there sealed units, i wouldnt prise them apart otherwise the damp will get in when there back together.The yellowing occurs on the outside of the lends, not the inside Quote
