dean@mainzcarcare Posted November 26, 2012 Share Posted November 26, 2012 The new innovative Pro-Buffing pad system designed to cut, polish, glaze and finish to a high gloss shine. Manufactured in the UK with the highest quality foam material available. Now with the unique "Hex-Tech" patterned foam enabling the best cutting, polishing, glazing and waxing/finishing surface. Long lasting and durable with accurate results giving you a safer and smoother polishing experience. The new Hex-Tech Pro Buffing Pads have been designed for the enthusiast and professional market. So easy to use, effective but with a high standard that most require when polishing. Simply a ideal and excellent range of quality cutting/polishing & finishing pads that cover all angles and will suit all paint types which include German paints too. The uniqueness of the Hex - Tech patterned style cut pattern within the foam pad have been designed to polish all surfaces including flat/Angled and rounded surfaces to give the best possible finish, delivering maximum surface contact for the many curves on motor vehicles today. The pads are easy to move while correcting whilst the polish been evenly distributed throughout the pad. The Hex - Tech cut groove within the pad holds the suitable amount of polish required to cut and polish the paint surface. When the pad turns at the RPM's the polish moves with in the pad grooves dispersing the polish throughout the pad surface ensuring a full pad to paint polishing action. The Hex -Tech also reduces surface "unnecessary" heat while polishing. The Hex style pattern within the pad evenly distributes free flow air over the pad giving you a safer, smoother and cooler polish. Hex - Tech Pro Buffing Pads are Professional Pads are easy to wash, maintenance and reuse. Advantages of the Hex - Tech Pro Pad System • Innovative designed to cut, polish, glaze and finish • Hex - Tech patterned cut foam pad for the perfect finish • Designed for the enthusiast or professional • Ideal for all paint types and curve patterns • The cut groove holds the suitable amount of polish • Evenly distributes free flow air around the pad • Quality foam construction • Manufactured in the UK • Easy to use and clean • 100mm or 135mm These pads come in many different types.. Yellow - Heavy Cut/Compounding Pad Orange - Medium Heavy Cutting Pad Green - Heavy Polishing Pad White - Medium Light Polishing Pad Black - Finishing Pad Blue - Light Clean & Glaze Pad Red - Ultra Fine Finishing Pad Few examples images In 100mm range we do Orange, Green, White and Black pads In 135mm range we do Yellow, Orange, Green, White, Black, Blue and Red pads. So the all important price... 100mm range 1 pad - £4.05 2 pads - £7.69 3 pads - £11.59 5 pads - £18.25 10 pads - £36.45 Postage is £2.70 regardless of the number of pads ordered. 135mm range 1 pad - £7.20 2 pads - £13.59 3 pads - £20.49 5 pads - £32.49 10 pads - £64.79 Postage is £2.70 regardless of the number of pads ordered. You can mix and match the pads of course to create any kits you might want. If you need a backing plate for these pads they come in two sizes £9 for the 75mm backing plate, good for 100mm pads, or £12 for 125mm backing plate for 135mm pads There would be an extra £2.50 postage on top of the pads if you need a backing plate (due to the weight) Any questions just ask. We will run this for a few weeks and then sort payments out if people are interested. Many Thanks Dean Names ------- 1. Rob H - Orange, Green, Black, White, Blue, and a backing plate to match in 135mm please! - Total of (£46.69) 2. Danb - White black and blue in 135mm & Polishing and Finishing ones in 3" - Total of £30.17 3. 4. 5. 6. 7. 8. 9. 10. Quote Link to post Share on other sites
Amjad Posted November 27, 2012 Share Posted November 27, 2012 I'm not looking to buy any at the moment but these are nice pads, I was using the orange cutting pad and it works nicely Quote Link to post Share on other sites
dean@mainzcarcare Posted November 27, 2012 Author Share Posted November 27, 2012 On 11/27/2012 at 2:08 AM, Amjad said: I'm not looking to buy any at the moment but these are nice pads, I was using the orange cutting pad and it works nicelyThanks for the comment, as you say these are very nice pads Quote Link to post Share on other sites
Rob H@RCH Engineering Posted November 27, 2012 Share Posted November 27, 2012 What thread are the pads? I am going to have a set but need to know they will fit first lol Quote Link to post Share on other sites
dean@mainzcarcare Posted November 27, 2012 Author Share Posted November 27, 2012 On 11/27/2012 at 10:26 PM, Rob H said: What thread are the pads? I am going to have a set but need to know they will fit first lolThese are two sizes, 100mm (4inch) and 135mm (5.5 inch), if you need a different size then let me know what size your after and I'll work something out for you.Dean Quote Link to post Share on other sites
Rob H@RCH Engineering Posted November 27, 2012 Share Posted November 27, 2012 Its the thread size I need to know my polisher takes a M14 pad I just need to know it will screw on.Cheers Rob Quote Link to post Share on other sites
dean@mainzcarcare Posted November 27, 2012 Author Share Posted November 27, 2012 On 11/27/2012 at 10:39 PM, Rob H said: Its the thread size I need to know my polisher takes a M14 pad I just need to know it will screw on.Cheers RobThese pads attach to a velco backing pad mate. Quote Link to post Share on other sites
dean@mainzcarcare Posted November 27, 2012 Author Share Posted November 27, 2012 Added backing plates to the group buy Quote Link to post Share on other sites
Rob H@RCH Engineering Posted November 27, 2012 Share Posted November 27, 2012 I will take one of each of Yellow, Green, Black, Black, Red, and a backing plate to match in 135mm please! Quote Link to post Share on other sites
dean@mainzcarcare Posted November 27, 2012 Author Share Posted November 27, 2012 On 11/27/2012 at 11:55 PM, Rob H said: I will take one of each of Yellow, Green, Black, Black, Red, and a backing plate to match in 135mm please!Cheers matey Quote Link to post Share on other sites
Danb Posted November 28, 2012 Share Posted November 28, 2012 dean what are these like compared to the Chemical Guys hex logic pads? Quote Link to post Share on other sites
dean@mainzcarcare Posted November 28, 2012 Author Share Posted November 28, 2012 On 11/28/2012 at 8:58 AM, Danb said: dean what are these like compared to the Chemical Guys hex logic pads?These are very similar to the old style Chemical Guys hex logic pads, i.e they don't have self centering recess that the new CG pads have. Quote Link to post Share on other sites
Danb Posted November 28, 2012 Share Posted November 28, 2012 White black and blue in 135mm please dean Quote Link to post Share on other sites
dean@mainzcarcare Posted November 28, 2012 Author Share Posted November 28, 2012 On 11/28/2012 at 4:57 PM, Danb said: White black and blue in 135mm please deanAdded mate Quote Link to post Share on other sites
Danb Posted November 28, 2012 Share Posted November 28, 2012 That price right dean? Quote Link to post Share on other sites
dean@mainzcarcare Posted November 28, 2012 Author Share Posted November 28, 2012 On 11/28/2012 at 7:40 PM, Danb said: That price right dean?It is now, been a long day and still hard at it. Quote Link to post Share on other sites
dean@mainzcarcare Posted November 29, 2012 Author Share Posted November 29, 2012 Any more folks interested? Quote Link to post Share on other sites
dean@mainzcarcare Posted November 29, 2012 Author Share Posted November 29, 2012 On 11/27/2012 at 11:55 PM, Rob H said: I will take one of each of Yellow, Green, Black, Black, Red, and a backing plate to match in 135mm please!Should that be 2 black, or did you want Black and Blue? Quote Link to post Share on other sites
Rob H@RCH Engineering Posted November 29, 2012 Share Posted November 29, 2012 I was just looking at that lol can ya make it a white one please thats to see if I can rescue the old Peugeot lol Quote Link to post Share on other sites
dean@mainzcarcare Posted November 29, 2012 Author Share Posted November 29, 2012 On 11/29/2012 at 10:00 AM, Rob H said: I was just looking at that lol can ya make it a white one please thats to see if I can rescue the old Peugeot lolConsider it done Quote Link to post Share on other sites
dean@mainzcarcare Posted November 30, 2012 Author Share Posted November 30, 2012 Anyone else interested in some pads? Quote Link to post Share on other sites
dean@mainzcarcare Posted December 3, 2012 Author Share Posted December 3, 2012 Hoping to get these sorted this week, anyone else interested. Quote Link to post Share on other sites
Danb Posted December 3, 2012 Share Posted December 3, 2012 as per pm can you add the polishing and finishing ones in 3" to my order please dean Quote Link to post Share on other sites
dean@mainzcarcare Posted December 3, 2012 Author Share Posted December 3, 2012 On 12/3/2012 at 10:30 AM, Danb said: as per pm can you add the polishing and finishing ones in 3" to my order please dean Done mate Quote Link to post Share on other sites
dean@mainzcarcare Posted December 3, 2012 Author Share Posted December 3, 2012 This group buy will finish on Friday with payments to be collected over the weekend. Quote Link to post Share on other sites
