Hex Tech Pro Pad Range - Group Buy
The new innovative Pro-Buffing pad system designed to cut, polish, glaze and finish to a high gloss shine.
Manufactured in the UK with the highest quality foam material available. Now with the unique "Hex-Tech" patterned foam enabling the best cutting, polishing, glazing and waxing/finishing surface. Long lasting and durable with accurate results giving you a safer and smoother polishing experience.
The new Hex-Tech Pro Buffing Pads have been designed for the enthusiast and professional market. So easy to use, effective but with a high standard that most require when polishing. Simply a ideal and excellent range of quality cutting/polishing & finishing pads that cover all angles and will suit all paint types which include German paints too.
The uniqueness of the Hex - Tech patterned style cut pattern within the foam pad have been designed to polish all surfaces including flat/Angled and rounded surfaces to give the best possible finish, delivering maximum surface contact for the many curves on motor vehicles today. The pads are easy to move while correcting whilst the polish been evenly distributed throughout the pad. The Hex - Tech cut groove within the pad holds the suitable amount of polish required to cut and polish the paint surface. When the pad turns at the RPM's the polish moves with in the pad grooves dispersing the polish throughout the pad surface ensuring a full pad to paint polishing action.
The Hex -Tech also reduces surface "unnecessary" heat while polishing. The Hex style pattern within the pad evenly distributes free flow air over the pad giving you a safer, smoother and cooler polish.
Hex - Tech Pro Buffing Pads are Professional Pads are easy to wash, maintenance and reuse.
Advantages of the Hex - Tech Pro Pad System
• Innovative designed to cut, polish, glaze and finish
• Hex - Tech patterned cut foam pad for the perfect finish
• Designed for the enthusiast or professional
• Ideal for all paint types and curve patterns
• The cut groove holds the suitable amount of polish
• Evenly distributes free flow air around the pad
• Quality foam construction
• Manufactured in the UK
• Easy to use and clean
• 100mm or 135mm
These pads come in many different types..
Yellow - Heavy Cut/Compounding Pad
Orange - Medium Heavy Cutting Pad
Green - Heavy Polishing Pad
White - Medium Light Polishing Pad
Black - Finishing Pad
Blue - Light Clean & Glaze Pad
Red - Ultra Fine Finishing Pad
Few examples images
In 100mm range we do Orange, Green, White and Black pads
In 135mm range we do Yellow, Orange, Green, White, Black, Blue and Red pads.
So the all important price...
100mm range
1 pad - £4.05
2 pads - £7.69
3 pads - £11.59
5 pads - £18.25
10 pads - £36.45
Postage is £2.70 regardless of the number of pads ordered.
135mm range
1 pad - £7.20
2 pads - £13.59
3 pads - £20.49
5 pads - £32.49
10 pads - £64.79
You can mix and match the pads of course to create any kits you might want.
If you need a backing plate for these pads they come in two sizes
£9 for the 75mm backing plate, good for 100mm pads, or £12 for 125mm backing plate for 135mm pads
There would be an extra £2.50 postage on top of the pads if you need a backing plate (due to the weight)
Any questions just ask.
We will run this for a few weeks and then sort payments out if people are interested.
Many Thanks
Dean
Names
1. Rob H - Orange, Green, Black, White, Blue, and a backing plate to match in 135mm please! - Total of (£46.69)
2. Danb - White black and blue in 135mm & Polishing and Finishing ones in 3" - Total of £30.17
3.
4.
5.
6.
7.
8.
9.
10.
