Dan_Henderson Posted December 11, 2012 Posted December 11, 2012 Hi lads I fancey installing a drift style vertical handbrake , is it possible with drums? I'm aware mine is a cable at the minute, can I convert it without getting disks? Quote
morgey Posted December 11, 2012 Posted December 11, 2012 The normal braking (foot brake) is done by hydralics even to the rear, so its the same system as the hydrallic drift style ones as you would use for discs ;) Quote
Dan_Henderson Posted December 11, 2012 Author Posted December 11, 2012 spot on mate cheers for the info u legend! Quote
Starbo Moorley Posted December 11, 2012 Posted December 11, 2012 Yeh you just pipe it in tio the rear brakelines. Quote
Rob H@RCH Engineering Posted December 12, 2012 Posted December 12, 2012 you will still need the stock hand brake for the mot because you carnt have a hydrolic one for road use. Quote
