Dan507 Posted December 16, 2012 Posted December 16, 2012 http://www.ebay.co.uk/itm/JDM-TRD-2WAY-LSD-Toyota-Starlet-EP82-EP91-non-turbo-clutch-type-differential-/181044910561?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a271e19e1&_uhb=1Wouldn't mind this for myself as open diff's are gay as hell. Quote
Dan507 Posted December 16, 2012 Author Posted December 16, 2012 Yep, cheap as fuck BECAUSE it's for the N/A gearbox. Quote
Ryan-11 Posted December 16, 2012 Posted December 16, 2012 it will also fit an early modal gt gearbox Quote
morgey Posted December 16, 2012 Posted December 16, 2012 These 6 bolt diffs then? Whats the DIFFerence?? (lol cheap pun) Quote
Vincent-ep91 Posted December 16, 2012 Posted December 16, 2012 If i was in the market for a diff i would consider this.... you could get the crown wheel drilled. Two bolts will already line up anyway. its quiet easy to do.I've got a trd helical diff which has 8 holes on the PCD, and its connected to an N/A crown wheel (6 holes) so i could use a standard 4.3 final drive with it Quote
