Hi team thanks for viewing I'm looking for a certain laptop
Specs needed
9 pin serial port
And 32 bit running
A good battery life
It's only needed to plug in to the car and data log/tweek motec
It doesn't matter how old battered ugly it is, it will only get thrown in the car
I could get a USB adaptor but my early motec version is not compatible with them
I know I said old but must be able to run data logging
As you can tell I'm now expert in this field but I know some of you are!!!
Thanks in advance
Oh yeah.... Cheaper the better lol
Assuming you already have a laptop mate?
usb to 9 pin serial port: http://www.amazon.co.uk/gp/aw/d/B0018D01JS
Slightly more complex but more cost effective:
/>http://www.vmware.com/support/
Go on Desktop & End User, select Virtual Player.
Download!
Pick up a copy of a 32 bit OS and install it to the virtual machine. Essentially it runs like a seperate computer inside your system.
You will understand when you get it up and running!
Let me no what you think, or if you go that route and then have any dramas.
Look for something along the lines of a DELL D5** or D6** series, both have serial ports!
I normally hang onto a few of these when we get them in for scrap just for the serial ports. Check your local AD-Mag for them you can normally get them for pennies. If you need one more urgently go eBay:
http://www.ebay.co.u...=item3f2025da3e
Edited by DavidAshton
You wont find a laptop with serial on it these days thats an OLD connection tbh!
Only way is to go Serial to USB conversion... Used them before they work fine!
I defo wouldnt buy a Dell just for serial tho.. lol
HP EliteBook 8560P comes with a serial port :p
Best part of £1000 so might not be an option lol
