sosolid Posted December 23, 2012 Posted December 23, 2012 what grade oil and make r people using for glanza? last i used was 10 40 part synthetic castrol magnatec. Quote
Gainzy Posted December 23, 2012 Posted December 23, 2012 Am using 5w 30 fully synthetic vw oil every 3000 mile or so Quote
micky boy Posted December 23, 2012 Posted December 23, 2012 Im useing Toyota 5w30 semi on a stock engine! Think fully is way to thin on a 15year old engine!..Pluss over years i've found people that have use fully synthetic oil just pisses from every oil seal known on the engine lolBut eveyone has there own views on what they like to use Quote
Liam_D Posted December 23, 2012 Posted December 23, 2012 I run 5 30w fully synthetic blitz racing oil Quote
oilman Posted December 24, 2012 Posted December 24, 2012 HiI would use a 5w-40 synthetic and you will find those through the link below./>http://www.opieoils.co.uk/c-656-5w-40.aspxOut of those, the best ones are the Fuchs/Silkolene Pro S, Millers CFS NT/CFS, Motul 300V, Redline and Gulf Competition. The Motul 8100 X-Cess, Millers XFS, Shell Helix, Fuchs Supersyn and Mobil Super 3000 are good, cheaper alternatives.As a budget choice, a 10w-40 will be fine and I would either go for the Fuchs XTR, Shell Helix, Millers XSS or Motul 6100/>http://www.opieoils.co.uk/c-657-10w-40.aspxCheersTim Quote
sosolid Posted December 25, 2012 Author Posted December 25, 2012 hi guys fanks for replys. under the bonet it says 10 30 and seeing u cant get that in the uk the next choice would be 5 30 right? Quote
oilman Posted December 27, 2012 Posted December 27, 2012 Yes, 5w-30 is the closest to 10w-30 that is easily available, but you might find that a 30 is too thin and it could burn it off.CheersTim Quote
micky boy Posted December 27, 2012 Posted December 27, 2012 Used 5w30 semi for over 4year never burnt a drop from what i've seen in the starlet hand book you get from japan it says use 5w30 in the winter 10w40 in the summer Quote
Broony Posted December 28, 2012 Posted December 28, 2012 i use 5w30 fully synthetic ester shizzle from the oil man, was called silkolene pro s and i use 5w40 in the summer Quote
