1990timeismoney Posted December 29, 2012 Posted December 29, 2012 Hi all having problems with boost on my td04 im running all supporting mods etc and using a greddy profec a boost controller.The boost controller wont boost into positive boost im running the td04 actuator still. Ive also got engine management light on (52) about knock sensor which im still trying to find a second hand one to see if its just the sensor.I wasn't sure if the actuator mite be set lower than the boost controller.Any help would be much appreciated.thanks Quote
Spoon_tuned Posted December 29, 2012 Posted December 29, 2012 your better off checking the sensor first then if that doesnt work we could help out more Quote
Broony Posted December 29, 2012 Posted December 29, 2012 firstly:is the EBC plummed in correctly?is the ebc setup properly?what pressure is your actuator rated to? as the boost controller will only increase boost from that point when set upPictures help Peter Quote
1990timeismoney Posted December 29, 2012 Author Posted December 29, 2012 thanks for the replys i will ad photos in a min i installed it the same way as my last profec a setup should be set ok did a few power runs etc will the engine management light effect it Quote
Broony Posted December 29, 2012 Posted December 29, 2012 it could do depending on the fault it maybe throwing it into limp mode? (never had engine light problem my self)what the max boost your seeing atm? and what boost is your ebc set too?? Quote
1990timeismoney Posted December 29, 2012 Author Posted December 29, 2012 Boost controller is set to 0.7 on the dial it when boosting it just about goes to 0.1 and doesn't feel like it pulls much. Quote
