morgey Posted December 30, 2012 Posted December 30, 2012 (edited) Edit need a new tank!Put simply i need Ep91 n/a fuel tank No pump etcMaybe the straps (best to have them if youve got them if they have a tendency to break on removal?)Most Be able to post or reasonable distance to collect from norwich Needs the round type fuel pump mounting, pictured here...So lemme know what you got Cheersmorgey Edited January 5, 2013 by morgey
james@cjperformance Posted December 30, 2012 Posted December 30, 2012 ive a full assembly here you can have for postage costs dude. not sure if gt and na ones are the same though
morgey Posted December 30, 2012 Author Posted December 30, 2012 Awesome dude good to know! ill look into it and see if they're the same Cheers
_shaun_ Posted December 30, 2012 Posted December 30, 2012 Am sure I can whip mine of the glanza shell before it goes if your stuck
Idrees Posted December 30, 2012 Posted December 30, 2012 Depends what year your car is mate. There's two different types. I've got both types here too.
morgey Posted December 30, 2012 Author Posted December 30, 2012 1998 SR if that helps? Is there any differences that i can see visually without removing it?
WallaceGlanza Posted December 30, 2012 Posted December 30, 2012 (edited) The later has a circular pump cover, the earlier was slightly oval. You can check this just by popping the cover off under the back seat. Edited December 30, 2012 by WallaceGlanza
morgey Posted December 30, 2012 Author Posted December 30, 2012 The later has a circular pump cover, the earlier was slightly oval. You can check this just by popping the cover off under the back seat.Thank you my man, i was going to check this anyway see if this is where the leak was so ill take a pic when its off
morgey Posted January 5, 2013 Author Posted January 5, 2013 Right so had my car on a ramp earlier and my fuel tanks pretty much split in half around the rear half of it. I've whipped the pump cover off and I've got the round pump housing like soSo if any of you lovely fella's could check what tank it is you have and PM me with a price posted if you have the same as this please and thankyouuu
_shaun_ Posted January 5, 2013 Posted January 5, 2013 i have one sitting its got some surface rust on it but looks fine realy. ill grab some pics so you can see. if you can arrange a courier its yours
morgey Posted January 5, 2013 Author Posted January 5, 2013 i have one sitting its got some surface rust on it but looks fine realy. ill grab some pics so you can see. if you can arrange a courier its yoursCheers for the reply dude but idrees has sorted me out with one for a good price incl delivery. Thanks again everyone
