Snazzyblowfish Posted January 29, 2013 Posted January 29, 2013 New to owning a starlet, having a slight fuel cut issue and cannot work it out for the life of me, I've been told its over boosting but it's only boost 0.6bar. Any I'deas? Quote
Mike@TD.co.uk Posted January 29, 2013 Posted January 29, 2013 As above, what is fitted to the car at the moment? What boost gauge do you have fitted also? As accuracy of some cheaper gauges can be way off. Cheers Mike JonesTuning Developments Ltd Quote
Socks Posted January 29, 2013 Posted January 29, 2013 Could be boost creep... As the above folk have said tho... You need to let us know the full spec of your motor to help you! Quote
Snazzyblowfish Posted February 2, 2013 Author Posted February 2, 2013 Okay as far as I know mods are; Exedy clutch fuel pumpBlitz dump valve and intercoolerCT9 turboHks actuator The boost gauge, I'm not sure what make it is.I'd put a photo up, but I'm not sure how and I'm on my phone at the minute but ill get one up. Cheers guys. This is a real help, felt a little lost before. Quote
Addymk2 Posted February 2, 2013 Posted February 2, 2013 With all that done I would assume its decatted aswell. When it hits fuel cut how high is the gauge reading? Does It have the ability to show you peak values or anything? Could just be boost creep tbh mate Quote
Snazzyblowfish Posted February 2, 2013 Author Posted February 2, 2013 Oh also, it had a fcd with it, wired it in, and all it does is spit flames and rev no higher than 3.5k on any setting. I removed it after this. It's all well and good sounding like a rally car but not when you can't go anywhere. Quote
Snazzyblowfish Posted February 2, 2013 Author Posted February 2, 2013 Yeah it's decat. Well yesterday my friend tightened the nut up on the actuator as it was loose now it's boost about 0.7-0.8 mark. I don't believe it can show peak value. It's just a basic gauge that looks smarter than the basic basic ones. Of that makes any sense... Quote
Snazzyblowfish Posted February 2, 2013 Author Posted February 2, 2013 http://instagram.com/p/UY4APhrIKm/ Thats the boost gauge... Quote
Snazzyblowfish Posted February 2, 2013 Author Posted February 2, 2013 And also at the risk of sounding like an idiot, can someone explain boost creep to me? Quote
Addymk2 Posted February 2, 2013 Posted February 2, 2013 Creep is when the actuator can't hold a stable boost setting, usually down to the wastegate not being able to hold/release enough pressure.Are you sure that the FCD was wired in correctly mate?And yeah my car was creeping up and hiring fuel cut just with a decat and exhaust! Pain in the rear. Quote
Snazzyblowfish Posted February 3, 2013 Author Posted February 3, 2013 Right, this evening a friend of mine showed me a odd little trick that has worked! He cut a 2l coke bottle off about 1/16th from the top, cut slits in it ( so it could fold over itself) and put it into the intake where the mushroom filter attaches to the induction pipe (hence the slits), then we just kept cutting more and more of it off until it ran right, fuel cut immediately stopped, but it was running only 0.4 bar, so we cut a little more off each time till its running a steady 0.6 sometimes peaking to 0.7 (not sure why but I'm sure ill dig a little deeper and find out). Quote
Snazzyblowfish Posted February 4, 2013 Author Posted February 4, 2013 yeah sure ill try and sort it out step by step it'l be tomorrow now though, as it is dark and rainy :/ its simple to do just cut the top off the bottle, bang the neck into you intake and cut slits going towards the neck so it folds around your intake. put your filter back on, take it for a spin, if its under boosting, but a hole in it, test again and repeat until correct. Quote
Addymk2 Posted February 4, 2013 Posted February 4, 2013 So all it does is restrict the airflow to your turbo. I see. Quote
Snazzyblowfish Posted February 5, 2013 Author Posted February 5, 2013 Yeah, i thought it was quite nifty, il put a how to with photos and such up soon. Quote
