Jarrod Posted January 29, 2013 Share Posted January 29, 2013 Like title states do I need a silencer for a mot?. Its decated I believe I don't need a cat for mot if im correct. This is info I need ASAP, if anyone can give me a definitive answer please. Quote Link to post Share on other sites
turbo Grant Posted January 29, 2013 Share Posted January 29, 2013 Don't need one but the mot'er can decide to fail it if he thinks its excessively noisey Quote Link to post Share on other sites
Jarrod Posted January 29, 2013 Author Share Posted January 29, 2013 Sweet so if I wrap her and also bung her for mot 1 they won't no if have silencer 2 will be pacified by a bung. I have just fitted a side exit sounds lush but want to lose silencer Quote Link to post Share on other sites
turbo Grant Posted January 29, 2013 Share Posted January 29, 2013 As long as its not blowing and secure and not excessively noisey they can't fail it Quote Link to post Share on other sites
Jarrod Posted January 29, 2013 Author Share Posted January 29, 2013 Sounds reasonable I hope I find a mot tester as reasonable lol Quote Link to post Share on other sites
Liam_D Posted January 30, 2013 Share Posted January 30, 2013 Yeah as stated mate, its totally down to the testers discretion. Mines always been fine and i run a Buddyclub Spec 2 Quote Link to post Share on other sites
Flaminsam Posted January 31, 2013 Share Posted January 31, 2013 No you don't need a cat. As the other guys have said its up to the tester to say yes its fine or ouch my ears are bleeding. Your car is subject to a emissions test. Every car is. You car will fail a cat test. If the tester follows his guidelines in the testers manual, he should then do a vehicle specific test. With starlet gt's not being a uk car they are not on the data base. So the tester must do the minimum requirement. I.e a non cat test. This also applies for glanzas. Quote Link to post Share on other sites
Liam_D Posted January 31, 2013 Share Posted January 31, 2013 On 1/31/2013 at 8:20 AM, Flaminsam said: No you don't need a cat. As the other guys have said its up to the tester to say yes its fine or ouch my ears are bleeding. Your car is subject to a emissions test. Every car is. You car will fail a cat test. If the tester follows his guidelines in the testers manual, he should then do a vehicle specific test. With starlet gt's not being a uk car they are not on the data base. So the tester must do the minimum requirement. I.e a non cat test. This also applies for glanzas.This is spot on! Nice to see someone knows the score Quote Link to post Share on other sites
