Danza V Posted February 1, 2013 Posted February 1, 2013 Hey all. Czmbelt changed yesterday and no expense spared with the change as I replaced the tensioner , idler and belt. Belt supplied by idrees and is made for glanza v. However it's started to make a whirring noise but it's intermittent and goest happen on start up when cold but once warm and you put it in park it will whirr then quieter then start again.. Has anyone else had this issue?? Quote
H_D Posted February 1, 2013 Posted February 1, 2013 are you sure its the cambelt which is making the noise its seems starnge if it is. I have not come accross this before even when timing has not been set properly. Where all the camshaft caps put back in the original locations? Quote
Idrees Posted February 1, 2013 Posted February 1, 2013 It sounds more like a fanbelt noise mate. Have you tensioned them up properly? Quote
Danza V Posted February 1, 2013 Author Posted February 1, 2013 You can rotate them both just under 90 degrees... It's frustrating tbh. I was thinking bearing of some sort but yeah... I'm not sure. Everything was put back correctly. Quote
Sefton-EP91 Posted February 6, 2013 Posted February 6, 2013 Does it sound more like a screech? If it is, my water pump was screeching only when warm. I am assuming you haven't done the water pump whilst it was apart. Quote
Danza V Posted February 13, 2013 Author Posted February 13, 2013 Hey guys turns out belt was too tight, retensuoned Nd it's all good!! Quote
