I'm away to start building a 5e turbo engine this weekend, I have a 4efte and a 2nd gen 5efe with coil pack, what else would i need? Would i need loom and ecu from fte?
Swap the sumps and oil pick ups for the 4e items onto the 5e engine. You will also need to swap the oil filter housings as it has the turbo feed from the 4efte motor. Some say this can be held on with the one large centre bolt, others drill and tap the 5e block for the other 3 fittings.
You will also need the 4efte thermostat housing.
