Jarrod Posted February 10, 2013 Posted February 10, 2013 I need a new driveshaft for my mk2 k reg gt with abs I've been offered a non abs drive shaft but I'm unsure if it will be compatible Quote
daniel_g Posted February 10, 2013 Posted February 10, 2013 If it has the same amount of splines it should fit. Your ABS wont work though, its shit anyway, and the dash light will come on. Quote
Hawwy Posted February 10, 2013 Posted February 10, 2013 If got a abs glanza shafts think they same Quote
Jarrod Posted February 10, 2013 Author Posted February 10, 2013 Thanks mate and if can get a 100% that will fit ill have Quote
RicoW Posted February 12, 2013 Posted February 12, 2013 if splines are the same it will fit, you can try to get the abs ring off and put it on the other one.be careful not to break the ring Quote
