Chrishoughton1989 Posted February 11, 2013 Posted February 11, 2013 Hello all.Just wondering, I bought a second hand engine for my glazia v and it didn't come with the dizzy etc. if I just bolt my old one on how will I no the ignition timing is correct? Cheers. Quote
Chrishoughton1989 Posted February 11, 2013 Author Posted February 11, 2013 Is it not possible to set it using the marks on the cam ? On the dizzy end. Thanks. Quote
turbo Grant Posted February 11, 2013 Posted February 11, 2013 You can put it on close to your position of how your one is so it would run. But I wouldn't boost it till you have checked the timing with a timing light gun Quote
Chrishoughton1989 Posted February 11, 2013 Author Posted February 11, 2013 So if i look on old head and position how it was? That will be ok until I get it checked ? Quote
rmsnoel Posted February 11, 2013 Posted February 11, 2013 Short answer chris, no. I could bridge the pins and set my idle at 750_770rpm because I kbow ive no vaccum leaks and my throttle is set spot on but u are fitting a new engine. A timing light is 20quid or ask around, someones dad always has one. My timing light is 36years old and Im 29.You will use it again if you have it, 20quid is cheaper than than a cracked piston. Search how to set base timing. It 10° btdc on a warm engine with check pins crossed using a paperclip. Then when all timing is right you can set your throttle idle screw. Always check tps switch because its a on off type instead of the newer dimmer switch type. Quote
Chrishoughton1989 Posted February 12, 2013 Author Posted February 12, 2013 Thank you. Does anyone have any guides to all this. Timing marks ? Using the gun ? Thanks. Quote
AdamB Posted February 12, 2013 Posted February 12, 2013 http://www.toyotagtturbo.com/forums/showwiki.php?title=How+to+set+timing Quote
mech5107 Posted February 12, 2013 Posted February 12, 2013 Just a side note, I've seen that retarding the ignition to about 6 degrees, i gain a lot in mid range... and not actually loosing at high rpm... Quote
AdamB Posted February 12, 2013 Posted February 12, 2013 Just a side note, I've seen that retarding the ignition to about 6 degrees, i gain a lot in mid range... and not actually loosing at high rpm... You would net more torque lower down the rev range, but it will suffer top end, which is where maximum ignition timing works best. You would be best off seeing what it does on the dyno, but every engines different. Quote
