Roachy1994 Posted February 12, 2013 Posted February 12, 2013 my head cracked last week I am just asking people what could of caused it it cracked around the exhaust port bolt, I am thinking could it be from were my downpipe hasn't got a bracket as I seen quite alot does have brackets and all the stress could have just been on the manifold bolts of the weight of the turbo etc ? any suggestions please as I don't want to just put a another head on it and it crack again Thanks Rhys Quote
turbo Grant Posted February 12, 2013 Posted February 12, 2013 What manifold you got. Seen loads of head crack that stud mounting point on the gear box end Quote
Roachy1994 Posted February 12, 2013 Author Posted February 12, 2013 One off them rubbish ones it was on the car it's cracked in loads of places to I'm going to change it I'm about to put a build thread up now so Quote
turbo Grant Posted February 12, 2013 Posted February 12, 2013 The cheap manifold bow on the flange. I would say that's what's cracked your stud mounting hole Quote
Roachy1994 Posted February 12, 2013 Author Posted February 12, 2013 Okey so it's just the manifold that's my problem isir? Quote
turbo Grant Posted February 12, 2013 Posted February 12, 2013 I'd say so and probably over tightening of the nuts Quote
Roachy1994 Posted February 12, 2013 Author Posted February 12, 2013 If you go on my build thread I just uploaded who ever put the manifold on must of over tightened it as its got more thread showing than the other 3 bolts Quote
WallaceGlanza Posted February 12, 2013 Posted February 12, 2013 It's very common for the head to crack in that area, it happens on standard cars so the most likely cause is the restriction in the standard exhaust mani creating a build up of heat in that area. Quote
bucketep91 Posted February 12, 2013 Posted February 12, 2013 Mine cracked taking off the standard manifold so i wouldnt say its a problem with aftermarket stuff. Every one ive seen has cracked in the exact same place. Quote
dai_starletN/A Posted February 12, 2013 Posted February 12, 2013 mine cracked and broke off but i got it welded back on at an engine builder Quote
Roachy1994 Posted February 12, 2013 Author Posted February 12, 2013 That's basically what happened to mine I was just wondering why it happened I have sourced a new head:) Quote
