fremyjay Posted February 13, 2013 Posted February 13, 2013 Flushed my heater matrix out and changed fuses and still get no hot air into the cabin and with the weather as cold as it is at the moment im bloody freezing, does anyone have any ideas on what it could be, im going along the lines of the thermostat being jammed open but does anyone have any ideas if it could be something else?? Quote
Jim* Posted February 13, 2013 Posted February 13, 2013 My thermostat was stuck open and car would never get very hot Inside, now I've changed the thermostat it does get a lot warmer! Could be worth a go mate especially as there around £7 from ID workz Quote
fremyjay Posted February 13, 2013 Author Posted February 13, 2013 Fair one worth doing for that amount then, problem is it doesnt get warm, it depends on the outside temperature, if its freezing outside its freezing in the car, its its warmer outside its warmer inside?? Is confusing me slightly as too what it could be Quote
morgey Posted February 13, 2013 Posted February 13, 2013 Thermostat most likely then, easy job so, just need to rebleed the cooland but seems youve prob done that already anyway Quote
Danza V Posted February 19, 2013 Posted February 19, 2013 I had same issue, I replaced stat and the heaters got a bit warmer however I think my matrix s make red cause I checked my heater pipes in the bay and they're roasting,.. Quote
rmsnoel Posted February 19, 2013 Posted February 19, 2013 you should be able to here your flaps open and close if you listen carefully whilst turning the hot cold knob Quote
