Celica Seats if you swap your rails over. Out of the latest Celica, I fitted them in my V the other day.
On a side note, that was a 98 spec interiored V, although it has been done before on the older models. Only the 2 rear cushion bolts line up and you need to use a breaker bar to get the frames to line up with the holes in your chassis. Once they are in though they are monstrously comfortable, far more supportive than the standard seats and if your lucky you can pick a set up for £30 on eBay in good nick. Takes about an hour and a half to get them in because of the fiddliness of it all. (Seat back needs to be bolted up to starlet rail etc.)
Edited by Addymk2
Can fit pretty much any seats you want mate aslong as you get custom rails :) dean at Rw developments would be able to make you some up I think.
