Rihto, ive purchased another turbo kit, and im struggling too identify what the turbo is made up off.
It was a blitz k3 but has been rebuilt with a garret inlet housing but theres no number/id marks that i can see too identify what it is, anyone know how i can identify it ?
Measure the compressor diameter mate. Or measure the compressor inducer and exducer if you can. Also do the same for the turbine side as it will most likely have work done here as well if its some kind of hybrid.
Let me know the sizes and I'll have a look around for you to see what mix match of a turbo you have :thumbsup:
You will want to find out the A/R ratio of the replacement compressor housing.
Good turbo that, can produce some healthy power.
